brake bleeder questions
Ok, so I have determined I need a new master cylinder & brake booster too. I am thinking about buying a pressure or vaccum bleeder to make it easy. Anyone have experience with these? There are numerous kits out there-- from $50 to $300 and up. I am considering the 'cheap' $50 vaccuum pump one, because I can always use a vaccuum pump for other tasks-- but if it doesn't work well, that defeats the purpose of buying it to begin with. Anyone have any suggestions? Also, what about the 'speed bleeder' screws-- anyone have experience with those?
Clifford
Clifford
Originally Posted by lees99f150
I have the mityvac silverline pump. It makes it so easy to bleed brakes. If you use the speed bleeders then you will need to bench bleed the new master cylinder.
The mityvac was around $50 and is made by lincoln in the USA.
