Running 305/40/22's On New Body Style?
To all of you guys running 305/40/22 rubber on the new body style F-150's, did any of you have trouble with tire clearance issues?
I'd like to use that tire on my soon-to-arrive '05 XLT Standard Cab Shortbox. My plan is to probably leave the front at factory height and then shackle the back down 1-1/2" - 2". However, I don't want to go with this tire if I'm going to run into any problems with the set-up clearing the vehicle!
Thanks for any input you can provide!
Originally Posted by wandell
I've seen 305/45-22's on stock 4x2 04-05 F-150's. I'm sure you could have rubbing if the wheel width and backspacing were not correct.
It looks like you are actually running a higher profile (45 height aspect) 22" tire on your Expy -- I would think the wheel well of that vehicle is very similar to that of the F-150 (?). Any clearance problems with your set-up?
