Specs of 18" 04 FX4 Wheels?
Anyone know what the backspacing of the stock 18" FX4 Wheels is? I know they are 18x7.5...
I heard of people fitting 325/60/18 and even 35/12.50...
Im just wondering if that spacing is perfect to stay with in case I was to buy some aftermarket wheels or if I should go with a different backspacing. I dont plan on lifting my truck for the next year or so and am pretty satisifed with the leveling kit, I just need some nicer tires to match...
People say I cant fit those size tires mentioned above when Ive seen pics on the forum. Whats the disadvantages of mounting them anyway? I know manufacture site says at least 8-8.5 width minimum...how are these folks able to fit them?
Thanks.
Thanks.
Yoman is right. The backspacing on the factory wheels is 5 1/2 inches. I'd try to stick close to that if you go to an aftermarket wheel. Usually, running too wide a tire on too narrow a wheel will cause the center of the tread to wear slightly faster than normal. Similar to the wear you would get from running too much air pressure.
