Front brakes driving me nuts
I recently bought new front brake pads for my 2000 f150. (autozone)
After telling the knuckle head behind the counter, I didn’t want any pads that squeaked or emitted tons of dust, what do I get?
Pads that squeal. Folks it’s driving me nuts!
These are the ceramic shoes, just like what came from the factory (As I was told)
How can I get these to stop squealing?
It's getting to the point I rather ram the cars ahead of me, rather than appling the brakes.....
Re: Front brakes driving me nuts
Brakes are going to generate dust. That's how they work. Some pads generate less dust than others, but as the friction material wears away, it's got to go somewhere. To stop the swueal, use a semi-metallic pad. Also be sure they are equipped with the pad shims. It's a thin piece of metal that rides between the backing plate and the caliper. Without the pad shims, they are almost guaranteed to squeal.
-Joe
When you did your brakes did you pop your tins out and clean from behind them real good? Did you clean and greese the sliders? These are very important steps that are often over looked by the diy. Did you spray the backs of the pads with disc brake quiet? dont over look these steps, if you do these steps and your more likely to have a sucessfull brake job...Rob
