20" rim = less power???
Hi all,
I have a 97 Ford ext cab 4.6 V8. I currently have the stock rim and tires, 265/75/16. I am wanting to upgrade my rim and tires. I am looking at 20" rims and 285/50/20. My question is will I lose that much power going with that wheel/tire configuration? Also will I need to upgrade my brakes.
Betaman
Betaman
the wheel will be heavear, and you are going up in size so that will effect your overall gear ratio, so yes you will lose performanse it will take you more gas pedal to go the same speed as with your stock rims and tires, i think your stock brakes will be just fine with the setup mentioned,
