Leaking Fluid ??
Leaking Fluid ??
A couple of weeks ago I noticed a squeaking sound coming from my driver's side back tire. It sounded like a bearing when it is going bad. My dad and I pulled off the wheel and took the drum off and noticed fluid leaking from around the bearing leading into the axle. When the tire is on the truck you can see fluid marks on the inside of the tire underneath the truck. Is this likely differential fluid or brake fluid? Is it likely a seal around the bearing or something else? Any ideas on how difficult to repair?
