2005 FX4 18" wheel/tire blues
A leveling kit should be used at a minimum. Prudence would also suggest a gear change with a 35" upgrade. You will notice a significant difference in "off the line power". I have the '04 and live a 7000ft and sluggish is the best description of the acceleration I experience with the stock set-up.
i just put the cooper stt's on my 18's 35x1250
[IMG]https://www.f150online.com/galleries...w.cfm?num=7943[/IMG]
I'm in the same boat with the tire options for the stock 18's that are only 7.5" wide. I've already installed the leveling kit, and the stock 275/65-18's look way too small now. I don't want to trim any fenders or crank any bars. I've been told by a couple local dealers that 33's are the largest that can fit without any rub with only a leveling kit. I keep reading on here that 35's will fit without any rub with only a leveling kit. Looks like I will be going with the Nitto Terra Grappler 305/55-20's with aftermarket wheels unless I hear differently. If I can go bigger without any rub, please let me know.
