brake lights not functioning
duran,
Did you just look at the fuses, or did you check them with a test light or voltmeter? Sometimes fuses look good, but aren't. Check for voltage at the stoplight switch near the brake pedal. See if you see any change when you depress the pedal, it may be a stuck or malfunctioning switch. Check for voltage at the socket where the bulb goes also.
SL
SL
