need new pads which ones are best?
I really like Hawk HPS pads. I run them on my truck. Great pedal feel and stopping power. But they aren't dust-free. I'll take a little dust so long as I have good brakes.
I've heard good things about EBC also. I used to run them on a sportbike I once had, they were great. But I've never had them on a 4-wheeled vehicle.
Update... my opinion of the EBS's is somewhat diminished. I found out this afternoon they are gone, literaly. One of the pads broke off. I mean the pad material is somewhere on the side of the road somewhere. The other pad is worn down most of the way, in 20K. Also, when I pulled the pads off I found that the anti-rattle plates had gotten so hot that they were warped and most of the glue that held them on was burnt off. The plates were made out of steel, not the rubber/plastic kind. Appearantly last weekend when I was hauling a$$ out in the boonies I got them a little hot. Suprizingly the brakes never even started to fade, in fact they were stopping incredably well.
I only hit the brakes two or three times before I realized that something was not right, so the rotor is ok. I still have the stock pads so I threw them on that side until the Hawks that I orderd come in. However, I still think that the EBCs are good pads. In fact I had ordered from the Tire Rack, only to find out they they were no longer being sold there.
Joe
Joe
"Update... my opinion of the EBC's is somewhat diminished. I found out this afternoon they are gone, literally. One of the pads broke off. I mean the pad material is somewhere on the side of the road somewhere. The other pad is worn down most of the way, in 20K. However, I still think that the EBC’s are good pads."
Geeeze, Wookie you don't ask for much, the pad fell apart!? I would go nuts on EBC; this is a rather important part (safety) of a vehicle.
They were great pads until yesterday afternoon. I think that the pads falling apart had a LOT to do with the way that I drove last weekend. I really put the pads through hell. What I think happened is that the brakes got so hot that the glue melted. Like I said the anti-rattle plates were warped/shrivled up from the heat. Even this hot the brakes worked perfectly. If they had better glue the pad would be spectacular.
Joe
Joe
WTF? Can't stop for crap with Motorcraft pads?
Just had my front pads replaced yesterday. The POS that I had put on by Brake Stop were almost down to metal on metal at 10-friggin-K miles!!!
Anyway... they stuck motorcraft ceramic pads on... and I couldn't stop for ***** the whole way home. Felt like I was pressing down on a cement block when I pushed the brake pedal... and I couldn't stop by slamming on the brakes... only coasting.
Took it back and the shop didn't understand why that was the case (though they felt something wasn't right when they test drove it as well). Needless to say, they just called and replaced those pads with AC Delco ceramic pads. I've never had this happen before with brakes... especially since the shop is telling me that the Motorcraft ones are original equipment model vs. aftermarket AC Delco ones.
We'll see what happens when I pick it up in a few hours.
Guess I need to start a new thread on this too.
Later,
Jeff
Later,
Jeff
Well, just picked up the truck.. the Delco's seem much better, but I need to spend the weekend with them to see what I think... since my shop is only around the block from work here. Right now I do notice that compared to my old POS pads, these do require more "oomph" to stop... but I don't fear for my life like I did with the Motorcraft pads. I'm not sure if I just got two bad pads or what the deal was. Anyway... things are better, but I'll hold off on saying they are "good" until I get some miles on them.
I'll keep everyone up to date.
regs,
Jeff
regs,
Jeff
