Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 10-03-2004, 04:55 PM
Garage is empty, add now
Vehicle: 1997 Ford F150
big tires require big brakes?
I am soon having my brakes checked, I also have 315/75/16 tires and tow a trailer 2 times a week (although the trailer has electric brakes). What, if any kind of upgrade should I be looking at putting on my truck. I know nothing about brakes!
Thanks!
2000 F150 Supercab XLT
5.4 V8 4x4
315/75/16 BFG A/T
4.56 front and rear
3" body lift
Old 10-08-2004, 08:59 AM
Vehicle: 2003 ford f150
tire size makes no difference, your stock brakes should work fine. your still trying to stop the same weight whether your using stock tires or 35" tires. the weight difference in tires shouldn't be a big deal.
True blue
2003 supercrew lariat 4x4
Light Gray Leather with 60/40 front
5.4 triton
trailer tow package
3:73 LS
access roll-up cover
3" magnaflow stainless catback exhaust
k/n air filter-gutted air box
285/70/17 Goodyear Silent Armors mounted on 10 spoke factory wheels,
Ford chrome tubular running boards
1969 Mustang fastback painted Ford Twilight Blue ,351 cleveland 4bbl, BlackJack Headers, flowmasters
c6 tranny, 3:55 rear, cragar pro street s/s rims with BFG's all around
Old 10-08-2004, 03:56 PM
Good call.
Old 10-08-2004, 04:03 PM
Vehicle: 1998 F150
They always promote bigger brakes if you go with bigger tires. It could just a scam to make you buy brakes though.
Here is a link for ya.
http://www.off-roadweb.com/tech/0311or_brakes/
Old 10-08-2004, 04:14 PM
Vehicle: 2003 Ford F-150
in my experience with more than a few vehicles any time you go bigger with a tire it increases your unsprung weight witch reduces your braking capabilitys, i know my truck with 38" brakes alot difrent than a stock truck, i still have the stock pads and roters tho all i did was upgrade to stainless braided lines, but when my current pads wear out i know i am getting better roters and pads
03 F-150 5.4 FX4 with HD supercharger swap at 10PSI, 6" fabtech with PA 3" body lift, 38"15.5" MT Baja claws, on 16" 10" extreem aloys, fabtech steering stabilizer, procomp traction bars, pro comp add a leaf, cranked torsion bars,4.88 gears, detroit locker in rear, ARB locker up front, troyer E-fans, X-cal 2 tuned by Sal, FTVB shift kit, on board air system, TONS OF CUSTOM MODS, AND ONE UNSTOPPABLE BEAST
Old 10-09-2004, 06:14 AM
Thanks for the info and the site. Anyone have an idea on how much a brake upgrade will run me?
Old 10-09-2004, 08:21 AM
Vehicle: 2001 Ford F150
Brakes
Not so fast on disregarding tire size to brake requirements. I'm no engineer (Accounting, FSU, 1982) but am often told I think like one. The MECHANICAL ADVANTAGE the larger tires provides in placing resistance against the braking contact surfaces can be significantly greater for a given amount of vehicle weight. Think of it this way-- a 12-inch diameter tire could easily be locked up with the brake pressure exerted by a standard disc brake setup, regardless of the weight involved (but the tire would certainly be worse for the wear... ). A 36-inch tire, on the other hand, with the same disc brake setup would be subjected to much greater pressure/resistance (which results in heat, a major factor in brake underperformance). This is of course an extreme example, but tire size is a signicant variable in determining braking efficiency.
Old 10-09-2004, 11:08 AM
Vehicle: 2002 Ford F150
Larger wheel and tire packages can most certainly use larger brakes.
Tires alone will not change this too much but if you replace the stock 16 with some 18s you'll surely notice a difference.
From experience; I took the alum 16s off and put on some MB's that were 18" and the closest set of tires I could find to the same diameter (or height) so to keep gearing close. Well let me tell you first hand the difference in weight (about 45lbs stock and 70lbs aftermarket if I remember) made a huge difference in the trucks performance. Or lack of.
But you asked about brakes.... not performance right? Same thing.
The added weight of the wheel while rotating at 70mph is going to take a hell of a lot more energy to stop than the lighter wheel.
Want to prove it in simple form? Ok. Take a 5lb rock on a string and swing it around your head, then replace it with a 7lb rock on the same string and see which one slows quicker when you want it to. Now do this with four rocks!
The bottom line is that YES larger wheels and or tires (considering they weigh more) WILL take more energy to stop them. And start them too, but that's the reason I took the MBs back off and they are collecting dust while I look for a buyer.
Old 10-10-2004, 09:03 AM
Thanks for the posts! All the input you guys provide is why I love this board. (then again I have never been to any other message board to compare). Regardles though I learn everything I need to learn right here.
Old 10-11-2004, 08:54 AM
Account Suspended For Violation of Terms of Service
Vehicle: 1994 ford f-150
brakes
yes, i would reccomend bigger brakes with bigger tires. bigger tires sort of have the lever effect. unless u like doing brake work alot :santa:
Old 10-18-2004, 11:30 AM
Vehicle: 1999 Ford F150
When you put larger diameter tires on a truck, your distance traveled per tire revolution increases. Then in turn, when attempting to stop in say 100', your brakes/rotors have fewer revolutions to work with in which to stop the truck.
When you upsize from say 29" to 35" tires your tire/rotor revolutions decrease by 17% ..... and so does your breaking ability.
Old 10-19-2004, 02:41 PM
Vehicle: 2010 FORD F250
price of brake upgrade
Gata... you asked about the cost of a brake upgrade... think BIG MONEY if you go with a "big brake" kit. I followed the link above which shows the install of a set of AP Racing drilled and slotted rotors (14"!!!) and new calipers and then checked the price through Stillen... upwards of $3800.
I, too, am no engineer... (Finance, CSU, Sacto, 1990), but I do understand the effect of rotational mass on braking forces as explained above much better than I possibly could. If you are noticing a marked degredation of your braking performance, you may want to check some of the other threads on this site for performance-oriented brake pads, upgrade your ROTORS to cross-drilled for better cooling, and upgrade to braided stainless lines. I've heard about upgrade master cylinders, but not sure if they're available for our trucks ~ probably not necessary unless you're getting really crazy with tire size. Just my .02.... good luck bro!
Old 10-19-2004, 02:47 PM
Vehicle: 1998 Ford F150
I just grabbed my spinning cieling fan from one of the blade tips, and ouch, but it stopped, then I tried it again from the inside, and lost a finger tip! - the fan is still spinning... aaah, the blood.. oooh
Well, it really didn't happen but I like DaveBeach's explanation!
Old 10-21-2004, 06:58 PM
Vehicle: 2010 GMC Sierra
There's no way you could get 14" rotors to fit in the 16" rims anyway. How about some of the power slot rotors? same size as factory but claims better stopping distances. Thinking of trying some myself. Oh yeah, and there a little chepaer than 3800 bucks!
Here's the link:
http://www.powerslot.com/platm.html
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
