Go Back   F150online Forums > Powertrain & Mechanical > Wheels, Tires & Brakes
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 05-22-2004, 02:02 PM
Garage is empty, add now
Vehicle: 1997 Ford F150
Brake smell???
Hi, I pulled two horses with my F150 yesterday. There were a lot of hills. I didn't have problems going up-hill, but breaking on the downhills might have caused the smell. It came from the driver side, rear near my tire. Is it possible that the brakes are being overused? The smell did not come from the trailer. I hear that the F150 brakes are naturally spongy. Thanks for your input.
Old 05-22-2004, 02:36 PM
Vehicle: 2004 ford rc f-150
Do you have drum brake's or disc brakes? If youhave drum's, than I can see heat having a harder time to disapate than disc.
If you don't have heat, than you will not have any smells, are your brake shoes setup properly, ie Adjusters?
How abought your axle seals, wheel cylinder, any chance of oil leaking on the brake shoes?
best of luck.
Old 05-22-2004, 03:48 PM
Welcome ! Your front brakes work substantially harder than the rears. They may have periodically overheated. If you don't visually observe the friction material and rotor/drum surface, you're left with speculation. How old are the brakes?
Old 05-23-2004, 12:35 PM
Smelly brakes
I bought the truck used, and I know that the brake pads were new when I bought the vehicle. It definitely has drum brakes, but I don't know if it has new drums or not. I'm thinking that I overheated them going down hill. Probably should have put into a lower gear. The trailer brakes work really well.
Old 05-29-2004, 04:27 PM
if you pull a trailer in hills for a good distance you're probably gonna smell em burnin a little.as long as you use common sense and don't ride em the entire time then you should be ok
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
