Ripple in sidewall
Old 02-28-2001, 01:18 PM
RipF350's Avatar
Question Ripple in sidewall
Last night I noticed that at least two of my tires have a ripple or indent in the sidewall going from the wheel to the tread. Is this something I should be concerned about? They are General Grabber TR's.
Thanks,
Rip
2001 F350 XLT SC Dually
V10 * 4X4
Westin Platinum Series Steps
Line-X Spray In Bedliner
[This message has been edited by RipF350 (edited 02-28-2001).]
Old 02-28-2001, 03:58 PM
Travis W's Avatar
Post
I have 4 symmetrical "ripples" or indentations on one of my goodyears also. Sounds like the same thing as yours. Anyone know what it might be?
97 supercab flareside 4x4, 5.4, cd changer, captians chairs, bedliner, hard cover, 17 in rims
Old 02-28-2001, 04:22 PM
truckluver's Avatar
Post
Are they indentions or extrusions? If they go out, then it means that you ran over something going very fast, a small bump or something. It will leave a little balloon in you tire, and it will dent your wheel. If there is an indention, I don't think that you have anything to worry about. If you don't get any feedback here, you might want to call your local tire company. Maybe you just rubbed up against something?
1999 super cab
white with tan bottom
automatic
4.6L v8
BFG AT TA KO 265/75
WAAG grillguard
2 KC daylighters
vampire remote start combo alarm
steelhorse nerf bars
Husky chrome toolbox
4 pioneer 3 way 6x8's
wants: 2 chamber flowmaster dual exhaust
tan fender flares
american racing atlas
2" fabtech suspension leveling kit
Old 02-28-2001, 05:39 PM
01sport's Avatar
Post
If is an indent running from the bead to the tread it is probably a ply splice. Where there is a splice you have a double thickness of ply. With the double thickness there is less give so it shows up as an indent. The tire is actually stronger in that small area.
If it is a bulge then it could be a sign of weakness in the sidewall or damage to the tire and should be checked out by the dealer or a tire store.
Old 02-28-2001, 08:56 PM
RipF350's Avatar
Post
It's definately an indent, not a bulge. Thanks for the info.
Rip
V10 * 4X4
Old 03-01-2001, 01:41 PM
max mitchell's Avatar
Cool
All 5 of my factory Generals have a slight similar production line.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Quick Reply: Ripple in sidewall
