Tire/Wheel choices
Tire/Wheel choices
This is truly a great message board - question: Ordering a new 2000 SuperCab 4x4 Lariat, but wanting to put some big new rubber on with some classy wheels, being a previous GM Man, I don't know much about how big you can go on these trucks without too much tire rubbing underneath...I want 33 or 35 inch tires, but how wide? If I lift it, I know I can go bigger, but I don't know much about lifting F150's (body vs. suspension)- bottom line, I found a deal on a tire/wheel combo from National Tire/Wheel:
BF Goodrich AT - 35x12.5R16.5
Eagle Alloy rim 589 - 9.75x16.5
Package costs about $1200
Good deal? Do I have to lift the truck? How much?
Any help is greatly appreciated
R.C. Windsor
General Motors Man, now converting to Ford Man - ordering 2000 F150 SuperCab Lariat 4x4 to modify extensively into an eyepopping wonder to behold! Give new meaning to "high-tech redneck!"
R.C. Windsor
Hi Captain Windsor
If you are going to put larger tires on your new truck I would sugest ordering the optional gears for your truck. I think they are a 373 gear ratio, also ge the limited slip if they offer it with that gear ratio.
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bassani Cat Back, Superchip,Modified intake with modified K&N filter.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
Hey Capt,
From what I've heard, 31"s are the largest you can fit before you raise the truck. If you search the board you should be able to find lots o' info. If you do go to raise it, I would suggest the suspension lift. A body lift is cheaper and easier but not as well suited for actual off-road use. If it's just for looks the body lift would probably work for you, although if you lift it much that way you'll be riding pretty high off your frame. Good luck and welcome back from the dark side.
1993 F-150 SWB Supercab 4.9l 4 speed auto w/ OD, 3.55 gears, K&N fipk, Custom Exhaust w/ Flowmaster.
But to chip or not to chip? Hmmmmm...
285's will fit without rubbing. I've also seen 33x11.5's on a stock 4x4 with no rubs. 33x12.5's Will fit but they rub a little.
For 35's you'll need a 3" body lift.
I see those 589's you're looking at. Well a couple of months ago I bought similar wheels. While I was looking for wheels American Eagle 589's 16.5x9.75 would not fit on F150's because of the bolt pattern. However I got American Racing Baja's In a 16.5x9.75 with 35 BFG AT's for $1244.00 Delivered to my door from 4wheelparts wholesalers. They look identical.
The Body Lift will run you $130.00 UNinstalled.
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, 5 Speed, Superchip, 2 Superchip Decals (I Think They Add 5 HP Each), 3 Inch Bullseye Lift Spindles, 3" Body Lift, 1" Coil Spacers, 3" Blocks In Rear,Manik Grill Guard,Nerf Bars, Vent Visors,Air Box Mod, Fog Lights Mounted In Front Air Dam ,4 Kc DayLighters, Back Up Lights, Alpine CD Player, 2 Kenwood Amps, 10 Inch MTX Blue Thunder SubWoofer, Tinted Windows. 35" BFGOODRICH ALL TERRAIN KO'S Mounted on 16.5x9.75 American Racing Baja Rims
<A HREF="http://www.zing.com/picture/pf95408d4c385a927598e7884a5151a2a/ffd9add3.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p7e554b755e2bb9aa66f774b76d669a34/ffd9add2.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/pe0557f5ae565a8da25e9ce11b08009df/ffd9add1.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p810cf5ac82eb57b84a62f699fb0f38e7/ffd9ad72.jpg" TARGET=_blank> </A> <A HREF="http://www.zing.com/picture/p3d23039451896f609154656f22698b8f/ffd991ca.jpg" TARGET=_blank> </A>
CLICK THE PIC FOR A BIGGER ONE
..........."IF YOU CAN'T STOP, SMILE AS YOU GO UNDER"...........
'00 Toyota Celica GT( Wife's Car )<A HREF="http://www.zing.com/picture/p5ef23f8639c03b4f05f21e4f35c15cfb/ffd9ad71.jpg" TARGET=_blank> </A>
Pics @ http://www.angelfire.com/la2/ccla/
[This message has been edited by ccla (edited 03-21-2000).]
Thank ya'll for the info - I like the looks of your truck ccla - it looks like I will want to go with the 35's and at least 3" body lift, maybe 4...just for looks and tire clearance mainly, I think those wheels look good - even though my last set of American Racing wheels were a little disappointing - they were clearcoated and it started to either partly flake off or fog up and I can't get the rest of it off - but anyway, I think I might try them...How quiet are the BFG AllTerrains vs. the MudTerrains?
R.C. Windsor
R.C. Windsor
Hey Captain Windsor, Pay careful attention to what Don C told you or you will be real sorry you changed tire size, real fast!
2000 F-250 Super Duty, Super Cab XLT, Oxford white with grey cloth captains chairs, 5.4L Triton V8(260 HP version!), 4R100 4 Speed Automatic Transmission, 4 wheel ABS, Deluxe Aluminum Wheels, Trailer Towing Package, Class IV Hitch, Reece load distribution system, Escort Sensor II Electronic Brake control, K&N filter, "White-White" head lamps.
