Engine problem
Engine problem
Iv been having a problem with my 88 ford 351. It will start and run but if you just hold it at a steady 2000 rpm it will just cut out like you turn the key off then it will rev back up to 2000 rpm and just repeat. Tried new tps, distributor, cap, rotor, wires, plugs, a computer from another truck fuel pressed is normal and still does it I'm at a lose. Would anyone know something else to try
thanks
thanks
