Spark Plugs Root Cause Transmission Issue
Old 02-27-2017, 06:29 PM
Modhydro's Avatar
2005 F150 4X4 134,000 miles, I am second owner @65,000 miles. Starts/Idle and Runs Good. I just noticed after warm up/8 miles cruising at 50 to 55 mph at immediate deceleration it seems to down-shift. And when I roll/coast/stop at a red light it remains in gear but when accelerated the transmission does not hold/remain engaged unless I let up on the throttle 2 or 3 times then it accelerates/shifts fine. This condition is easily duplicated. All fluid levels are good, no leaks, no abnormal odors, and no codes when checked at auto parts store O'Rilleys. I have read some information about Slight Spark Plug Mis-Fire might cause this, which sounds strange as the engine performance is good. Any Advise is Appreciated. Thank You.
Old 02-27-2017, 07:10 PM
glc is online now
O'Reilly's scanners can't read Ford transmission codes. There won't be any codes if the OD OFF light isn't flashing. Spark plugs will cause a miss or shudder under light throttle application at 40-45 mph in overdrive.
Old 02-27-2017, 07:16 PM
Roadie's Avatar
Are you saying the transmission is slipping?
Old 02-27-2017, 07:39 PM
Modhydro's Avatar
GLC = The OD Light is not flashing.
Roadie = From a dead stop (Red Light) yes it slips a few times.
Old 02-28-2017, 01:28 PM
What does the trans fluid level look like? Color? Smell? Feel?
Old 02-28-2017, 02:52 PM
Modhydro's Avatar
The fluid level was high when this problem developed, but it had been high for months. To get the level down i siphoned about two quarts out with a extraction device. This did not change the condition. Fluid Color matches new/unused fluid, Smell = not burnt/matches odor from new ATF. Feel/texture same as new ATF. I spoke with a Transmission Shop today, spark plugs could cause problem on acceleration. He will diagnose tomorrow.
