02 f150 fuel pump issue
Old 06-30-2016, 10:30 AM
Austin Minick's Avatar
I have a 2002 f150 with the 4.6 triton. When I go to start it in the morning it takes a couple of cycles of the key before it starts and even then it barely starts. Once it's running it idles fine but as soon as you take off it bogs down but kicks back up after a couple of seconds. When I'm driving the power will cut out anywhere from 50-6mph. And if you floor it it just bogs back down. Someone please help
Old 06-30-2016, 11:19 AM
Roadie's Avatar
Definitely check the fuel pressure. If it's okay, check the cats for back pressure.
Old 06-30-2016, 01:30 PM
glc is offline
When was the last time you changed the fuel filter?
Quick Reply: 02 f150 fuel pump issue
