2005 f150 5.4 cam failure???
Hello all I've got a interesting situation here with my 2005 f150 with 5.4 3v. It died on me and after finding out the passenger cam had stopped turning I removed valve cover also timing cover to find what looks to be a cam follower has failed and busted which caused cam to jam and then sheared bolt on cam sprocket. So would my next best check before pulling head off be to do a compression test on that side? First I need to get new cam and new chain installed before I can do compression test. Also can I do compression test with everything removed from engine? Thanks
I have researched and it definitely is a interference design engine but have heard thatsometimes you get lucky where the cam stops and valve damage does not occur. I can only hope for that
