reuse of TTY connecting rod and main cap bolts
So, I've been rebuilding a 1999 4.6L Romeo SOHC for my 1998 F-250. The carbon was caked on the top of the pistons pretty damn good and I wanted to clean that off, check the rings, hone the cylinders, pop the expansion plugs out, clean everything out, and give it a nice paint job before reassembly.
So far, I've dropped $475 on the engine and have been comfortable with the replacement part budget at around $600 for various stuff I need (seals, gaskets, bearings, bolts, etc ... mostly from RockAuto)
It was going great until I read the part about the main cap and connecting rod bolts being torque-to-yield (TTY) and needing to be replaced, like the head bolts, which I already knew about.
I figured it was gonna be no biggy. After all, the TTY head bolts run around $16 for each set.
Boy was I in for a terrible SURPRISE! It turns out, these stupid bolts can be the most expensive part of a rebuild.
So far, for the connecting rod bolts, all I can find is:
ARP-256-6301 ~$150
genuine Ford $12.38 X 16 = ~$200
For the main cap side bolts I found:
ARP-156-5201 or ARP-156-5202 ~$56 (not sure of the difference)
I can't even seem to find the main cap top bolts anywhere.
I guess my question is: Am I insane to try reusing my TTY main cap and connecting rod bolts?
From what I've read so far, the picture I'm getting is:
TTY head bolt reuse: completely insane (didn't expect to)
TTY connecting rod bolt reuse: somewhat insane
TTY main cap bolt reuse: mildly insane
I figured I'd check with you fine folk. Being on a budget, I'm not thrilled at the idea of spending $200 - $300 more on some frickin' bolts than I was expecting. This is a work truck. I pull trailers, but I don't race the damn thing.
Thanks,
Steve
Kissimmee, FL
ARP-256-6301 ~$150
Thanks,
Steve
Kissimmee, FL
Seems that I missed the part where the Ford connecting rod bolts came 4 in a pack for $12.38 http://www.fordparts.com/Commerce/Pa...rd&model=F-250
at $49.52 for all 16, I'll get the rod bolts ... just debating on the main caps now
full set of main cap side bolts for ~$30 http://www.fordparts.com/Commerce/Pa...rd&model=F-250
8/10 of the main cap top bolts for ~$30 http://www.fordparts.com/Commerce/Pa...rd&model=F-250
talked myself into doing at least that much ... there's at least one studded bolt on one of the main caps for holding the oil uptake tube. I think I'll take my chances with reusing that one and one of the other "regular" main cap top bolts.
It looks like fordparts.com now redirects to parts.ford.com and the selection is only 5% of what it was before. I don't know what the hell happened here.
Any Ford dealer should be able to order the bolts for you.
The engine ran great when I was finally done btw.
