leak-down compression tester recommendations?
Old 01-21-2016, 06:53 PM
smaring's Avatar
I managed to pick up a $40 leak-down compression tester from Harbor Freight that seems to be worthless. I'm pretty sure the plugs in this '99 4.6L v8 have a 14mm threading on them, but I just can't get the 14mm adapter that came with this stupid thing to thread.
I really wanted to get a leakage baseline test on this thing before I rebuilt it ... so I can at least feel like I made some progress.
Can anybody recommend a tester that doesn't break the bank and actually works?
Anybody use the OTC 5609 Cylinder Leakage Tester Kit?
Thanks,
Steve
Kissimmee, FL
Old 08-01-2016, 06:43 PM
smaring's Avatar
I looked closer at the threading for the plugs and was a bit surprised at how few threads there actually are to hold the plugs in ... especially considering its aluminum! geesh
Even with the o-ring off the adapter I still couldn't get it in far enough to start to thread. It does seem that the issue is that this adapter is just too short, but I'll be damned if I can find a longer one.
Looking at this threading makes me wish I had retapped these things to M16x1.5.
Old 08-01-2016, 08:00 PM
smaring's Avatar
I found an M14 long thread hose on Amazon for $18 that I'm gonna try here in a couple weeks.
Quick Reply: leak-down compression tester recommendations?
