Which Motorcraft plugs to buy?
Thanks, glc. I will look at those.
Anyone used Delphi coils? A bit more expensive than Motorcraft on Amazon.
Not sure I need coils, but 146k on the truck and I plan on keeping for quite a long time. At least 5-6 years more at least. Put about 12k on it per year. Got a lot of money in it thus far on other repairs and accessories. Latest is new stereo and speakers. Next is rigid fogs and maybe a light bar in bumper.
I may have a miss. I have that shudder many speak of in overdrive under light load/throttle and its getting more profound each day. Troubleshooting for water now, and have two more coils to pull tomorrow. Took and decent splash on pass side in some heavy rain. Big hidden puddle in town.
No codes. After cleaning them up, including dielectric, is there a way to test them individually? Mechanic says GM computer will give you a spark/misfire report per cylinder where Ford does not.
I found boots WR-6131 on amazon but it doesn't state if spring is included.
WR6131 does not come with springs.
You can buy Standard CPBK240 from rockauto.com for $21.79 a set. That's boots and springs.
Change the plugs, boots, and springs and see how it runs. If it still misses, buy a set of the Araparts cops and save the old ones with the new boots and springs.
Cleaned up all cops and plug holes with brake cleaner and blew it all down with air compressor. Fresh dielectric too. No sign of water but down miss is gone.
67 k on current plugs, so will do those sooner than later just because and a boot kit.
Side note : anyone use MSD cop?. Rock auto has those as well.
