Has anyone used Cataclean
Yes I tried some in a 2000 Honda CRV. The check engine light came on and the code was something with the catalytic converter. I followed the directions and no longer got the cat converter code.
NOTE 2000 is an OBD2 more sophisticated than your 1995 OBD1, which probably wouldn't have a code for a bad cat converter. Also I wasn't losing power or anything, so my converter likely wasn't plugged.
I don't know if this stuff would work on a badly plugged converter, but if you try it I would do one bottle at a time and follow the directions.
Or you can do this yourself. Go to Harbor Freight and buy one of their Laser Temperature Probes for 36 bucks. The max range on them is about 950F. The normal temp on a cat for your rig is between 500 and 800F, Anything hotter and they are plugged. Just take the truck for a 30 minute drive and crawl under it. FWIW, it take temps in the 2000F range to melt the catalyst. An engine that is burning oil will coat the cat and render it useless and will eventually cause it to plug. Hopefully you've not been cramming Seafoam oil down the the intake.
As I said before, with cats only and no mufflers, it should be VERY LOUD. If it isn't, your cats are clogged.
It's not that hard to figure out a way to gut them, shouldn't cost you much. If that fixes it, throw a cheap muffler on it to preserve your hearing and keep your sanity, and call it good for now. If you have emissions inspection, you will have to replace them with cheap universal cats.
I'd see about dropping the pipes off the outlets and ream them out with something - then start it, rev it up, and blow all the loosened crap out of them. Reconnect the pipes.
