Intermittent Crank No Start Problem
2001 Ford F-150 4.6L V8
So for the past 2 months I have been having an intermittent crank no start problem with my truck. The truck will run fine for a week or so then when I go to turn it on in the morning and it will crank but not start. I leave it alone for a couple of hours, comeback and it starts right up. It does this once or twice every 2-3 weeks. Once it turns on it runs good and won't do it again for a while.
Was told it was fuel pump problem so I replaced the fuel pump. Truck worked good for a week before it started happening again. The mechanic said it is the fuel pump again. Haven't been able to test the fuel pressure when I am having the no start problem since I don't have a gauge.
The only code I have is a P0430 - Catalyst System Efficiency Below Threshhold (Bank 2)....
Does anyone have any idea what it is/could be...
You don't necessarily have to have a gauge - you can tap the Schrader valve on the rail and see if fuel sprays out.
When you turn the key to ON, do you hear the pump run for a couple seconds?
You need to get that cat issue fixed, it may be clogging up and the backpressure will do some nasty things to your engine.
So I filled the truck up yesterday and this morning it wouldn't start. I tried as you said holding the pedal down slowly, which didn't work, then floored it and it turned on. I also forgot to mention that it usually messes up when I fill the truck up. Once it gets down to 3/4 tank it is problem free till I fill it up again.
That sounds like leaky injectors. Need to get that fixed before it hydrolocks. The leaky injectors can also trash the cats.
Another possibility is a problem in the evap system, dumping fuel into the intake. Next time you fill it, don't top it off after the nozzle shuts off, or only fill it to 3/4.
