1993 f150 v8 302 cranks but wont start HELP!!!
I am at wits end trying to fix my truck and would like to pick your brains, if I could.
I purchased my truck 3 weeks ago from the original owner. It has 142k on the clock.
I drove the vehicle home 50 miles without a hiccup. The next weekend I decided to give the truck a tune up for my own piece of mind which was going to be followed with fluid changes etc.
I changed the plugs and wires went to start the truck and it would crank but not run. I then went back to the forum searches and decided that maybe I needed an ICM. No change. New coil, No change, New distributor and viola fired right up. I let it run for a few minutes as i put my tools away, then took it out around the block. It sounded and felt like it was running 10 times better... then after maybe 2 miles as I was pulling up to a red light it died. It would crank but not turn over. I had it towed.
Back to the forums i go...
I have 40 # of pressure at the rail when I jump the #2-#6 pin connector (with the pcm connected) from both tanks but no spark just cranks. When i disconnect the pcm I have spark and I can get it to turn over and fire with starting fluid. So I think pcm is bad. I pull pcm, inspect it, looks magnificent, no burns, smells etc. but i go and get a new pcm.
New pcm installed and connected. no change. acts just like it did with my previous pcm.
Where do I go from here?
Kush1
Kush1
On the front of the dizzy you have a Ignition Control Module. These have an aluminum heat sink inside and are a known issue with this type of ignition. They will heat up and it's like turning the key off. Sometimes it will start and run, sometimes it won't. If it's a rebuilt dizzy you installed, my money is on a bad ICM. It's the little gray thingy on the front of the dizzy. Costs about 75-90 bucks. Use ONLY a Motorcraft part or expect issues.
