2002 4.6L so many codes
I've got 265,000 and I have done a lot of work but I haven't seen this many codes at one time. I have P0301-8, the p0401egr code, and then I have a code that I can't remember I think it is P0415 and it said a hose is off or something like that(not exactly sure because the parts guy insisted on holding the reader and kept getting in the way). When I am driving it basically feels like the motor dies and instantly start causing a hesitation then jerk. It won't hardly pull a steep hill. It is worse with A/C on.
My question is do you think a new set of COPs and plugs might solve the problem? Could all of them flake out at the same time or do I have some bigger electrical problem?
Update
I looked at dpfe to make sure hose isn't rotten. I had already ordered a set of COPs so I replaced #4. I always unhook battery when I do that so afterwards I drove to parts store and it isn't missing or throwing codes so I'm going to hold off on throwing any other parts at it until it throws codes. I know it needs a TB cleaning but that is something I don't have the time to do myself.
on
He has codes that are directly contradictory (P0401 and P0402). You cannot have both excessive and insufficient flow if you have clogged EGR passages.
The factory sensors of that era were so prone to failure that Ford issued a TSB telling dealer techs to automatically replace them FIRST, then see if anything else was amiss whenever an EGR fault code was found.
