Dead spot in power band
Old 08-10-2015, 06:35 PM
Bwidener1975's Avatar
Ok, I have a '99 f150 with 4.6. It runs great, idles fine. But under moderate to heavy acceleration , it will hit a weak spot in the power band. But once it gets past the week spot it will continue to speed up like it should. Any tips or suggestions? Thanks.
Old 08-13-2015, 12:29 PM
2008_XL's Avatar
Dead spot? Do you mean like a misfire?
Have you checked for any pending codes?
Old 08-17-2015, 11:33 AM
No, no misfire, when it hits a certain rpm its looses power and when it gets past that point it gets power back.
Old 08-17-2015, 11:34 AM
...and no sel.
Old 08-18-2015, 03:11 PM
"Service engine soon"
Old 08-18-2015, 07:10 PM
Zilla98's Avatar
Having any exhaust problems, like clogged cats or anything? My truck kicks in like it has V-Tec, I chalk it up to my factory cats being clogged.
Old 08-18-2015, 08:06 PM
Maybe clogged cats...how do I check?
Old 08-18-2015, 08:46 PM
Roadie's Avatar
A muffler shop like Midas can check it for you. I had one checked several years ago and they drilled a hole in the exhaust in front of the cat and used the hole to check the pressure while revving the engine. Mine was okay.
Old 08-18-2015, 08:47 PM
Zilla98's Avatar
In my case, I could hear the internal workings of the driver side (by the door/fender area) cat rattling around a little. After starting it up on a cool morning, I got under it and could see water dripping out of it (it being the catalytic converter), which meant it had already rusted a small hole in itself from trapping that moisture in.
Old 08-19-2015, 10:02 AM
Well, the cats don't appear to be rusted, not dripping water, no rattling sounds and no funny smelling exhaust.
Quick Reply: Dead spot in power band
