P2198, white vapor, and loud knock
2006 F-150 XLT 5.4L 4x4 103k miles
So first a little history. In April my truck was running very poorly, with a misfire on cylinder 4. Turns out when previous owner had plugs changed they installed Champion plugs which I've been told is a no no. I installed new motorcraft plugs myself and it has been smooth sailing until today.
This afternoon it was idling while i was hooking up my boat and suddenly started pouring white vapor/smoke from the left tailpipe (true duals) and missing. It through a code P2198 which is O2 Sensor Signal Biased/Stuck Rich (Bank 2 Sensor 1) Code. I was going to take it to my local shop up the road where my buddy does hella good work. However, I went to start it and now it has a horrible knock and I'm scared to drive it (the shop is about 3 blocks straight shot). I'm embedding some videos, if you guys have any insight it would be greatly appreciated.
I think I listed everything here, if you need anymore info just ask. Thanks guys.
No misfire code man. The smoke/vapor would completely saturate my hand in a few seconds. The coolant level has been steady since i bought it and i cant tell any change in color other than it being old coolant (and probably due to changed)
However its worse now. It sounds like something metal is broken and slamming around when you crank it.
As I dont feel like i have much to lose I may pull the valve cover off today after work and see what i can find. Is it possible the cam phaser went? Would that cause a run rich issue?
Well needless to say I'm now in the market for a used or reman motor. Dealership explained a stuck injector cause a hydrolock and I now have a nice hole in my block and puking oil everywhere when it's running. Of course they want $8900 to stick in a reman.
Sucks that knowing what I know now I see many threads of people with the same issue, could've saved me a little headache and a lot of money I'm sure.
So should I go with a local used motor (118k miles $2100 30 day warranty) or pay the extra $1k or so for a reman with better warranty? Opinions?
It seems like to me that more than likely my truck would have the same darn injectors that the 05's had right? That should be enough for Ford to extend the warranty in my mind.
