5.4 v8 triton ignition coil b primary and secondary malfunction
Old 03-20-2015, 10:37 AM
jplant36's Avatar
so i recently bought a 07 f150 5.4l v8, tritons are clearly crap but before i bought it the dealer put new phasers and solenoids in it. drove good for about a month now its misfiring like crazy. had coils and plugs 1-4 replaced and made it driveable but now im getting the ignition coil B primary and secondary malfunction. at this point i have no idea what the problem is and looking for any help i can get, been told to just get a new engine so im looking for options so im not out another 7 grand. not a mechanic and dont do my own work but any info i could pass onto someone to get this fixed quickly would be appreciated, dealer also wont help and im thinking when they put the new phasers in they did something wrong.
thank you in advance.
-jon
Old 03-20-2015, 11:41 AM
glc is offline
What is the exact numeric code?
Old 03-20-2015, 11:48 AM
jplant36's Avatar
honestly i was in a rush and didnt write the code down but im going to run it again in about an hour and ill post it up when i get it
Old 03-20-2015, 08:30 PM
jplant36's Avatar
ran the codes again and got
P0352 ignition coil b primary and secondary circuit malfunction
P0113
P1000
Old 03-20-2015, 09:20 PM
glc is offline
Causes of P0352:
- Faulty Ignition Coil 2
- Ignition Coil 2 harness is open or shorted
- Ignition Coil 2 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
#2 is the second one back from the front of the engine on the passenger side.
P0113 is Intake Air Temperature Sensor Circuit High Input.
- Faulty Intake Air Temperature (IAT) sensor
- Dirty air filter
- Intake Air Temperature (IAT) sensor harness is open or shorted
- Intake Air Temperature (IAT) sensor circuit poor electrical connection
This makes me a bit suspicious - someone may have installed a cheap "chip" that allegedly improves performance and economy. They are resistor packs that "fool" the ECM into thinking the intake air temperature is something which it isn't.
You don't need a new engine, you just need to fix a couple electrical glitches that are no fault of the engine itself. Any reasonably competent shop should be able to fix these 2 issues, unless the ECM itself is shot.
Old 03-21-2015, 12:33 AM
jplant36's Avatar
Causes of P0352:
- Dirty air filter
thanks for the help im gonna look into what you said some more, taking it to a shop tomorrow
Quick Reply: 5.4 v8 triton ignition coil b primary and secondary malfunction
