2005 5.4l 3v intermitting cam code.. help!!!
alright fellas, i got this truck in my shop for a coworker and he has had multiple mechanics look at it for him and couldnt figure out what was wrong with it.. i diagnosed the cam phasers, replaced and installed the new ones along with retimed the truck. it started out with 22 fault codes. i dropped it down to 13 with the phaser swap. and now down to 2 codes with the cats unbolted. i have 2 cam codes. both the cam sensor circuit a bank 2. one intermitting, the other just the cam sensor circuit. i have swapped the sensors from side to side to see if it would follow the sensor. nothing. swapped the vct solenoids from side to side to see if it would follow. still nothing. fixing to chase the wire to the computer to see if thats the issue. also goes into limp mode when you reach over 2500 rpms after you clear the codes. my concern is to in what world would cause this?????
**** doesnt help he has driven it with it all goofed up for over a year
