Truck will not start
Hello, I have a F150 v8 4.6L and it will will not start. Also, the odometer reads "---------" and the gauges turn on along with the theft light flashing rapidly. It turns over but will not always start.
I've had this problem before and it seemed to be fixed for a couple weeks after the computer was reprogrammed.
It will start if I leave the battery disconnected and the key on the "on" position then connect the battery.
Any ideas what is causing this issue?
Sounds like it may be time to go visit a dealer once you get it started. Either the chip in your key is going out or the PATS transceiver in the steering column is going.
Don't even waste your time trying to start it if the odometer is all dashes and the theft light is blinking rapidly, all you will do is kill the battery.
