5.4 misfire. Flashing check engine light? Please help
So a couple weeks ago my truck started jerking between 35-55mph at first I thought this was a transmission issue. After it finally threw a code I later found out this was a misfire in cylinder 2. I replaced the plug and coil pack without breaking the plug and it still acts as if it has a misfire... Lack of power, runs a little rough? Does anyone have any suggestions or could you give me any kind of help to what may be my problems. Please.. Open to any suggestions
Have the same issue. Flashing engine light and misfire codes. Mine is caused by the variable timing being "stretched" or something like that. Couldn't get the timing right in the truck before all this. Then ford came out with a magical CPU update and poof. No more timing and misfire issues. But, after I pulled a 20' decontamination trailer I got the flashing engine light and misfire codes. I'm upgrading my timing setup with the parts Ford came out with to correct the stock setup. Supposedly that will permanently correct my issue. We will see. Hope yours isn't that. It's not a cheap repair. Having your CPU flashed with the latest update may solve your problem. My truck was just to far gone for it fix.
