Help please idle problem, drops hard during braking
Hello I have a 2003 4.6 2wd f150 and the idle has seemed off for a while when the car first starts it goes to 1600-2000 rpm and hangs there for a little bit then drops fast to around 500-800 the worst part is that when I'm driving as I am coming to a stop and start hitting the brakes the eps do not drop they will hang at about 1500 until I am almost stopped and then drops down to 500 or a little lower and then it surges a bit, I have no clue what it could be it feels like I am still pushing the pedal while trying to brake anything helps
Thanks in advance for any ideas
Also, check your EGR valve and make sure it's not sticking open causing an intake leak.
Vac Lines, something else to run down.
One trouble shooting method I've used is when the idle is dropping low, try unpluging the Idle air control valve, or the Mass Airflow sensor, or the throttle position sensor... etc...
and look for something to change.
Frosty
Frosty
