New Truck, werid sound
So I just bought my first f150 a couple days ago. During the test drive I heard what appeared to be a diesel sound. I asked the dealer if he had it checked out and he said yes. I expressed concern about the cam phasers he informed me he thought the same thing when he took it to the mechanic but the mechanic said its not a phaser and its just a normal 5.4 sound.
I went over the truck with a stethoscope and it sounds like the its coming from the passenger side valve cover area. Only symptom (that I can tell) is the diesel sound. no lack of power. And it does this when its cold and hot. just on idle. Ideas? things I should check before jumping into a phaser job?
Thanks!
Thanks!
Perchance, did the mechanic:
- observe /log the VCT PID's as live data?
- temporarily unplug the VCT solenoids - one at a time - to see if the noise stopped? (you can try this too)
-pull the existing VCT solenoids and inspect them fer blockage/missing screens, etc?
-try a pair of New-revision VCT solenoids? Part # = 8L3Z-8M280-B
-pull any codes?
-measure oil pressure @ idle? ( low oil pressure will affect chain tensioners )
... just thinkin' out loud ...
