06 misfiring
06 misfiring
Hello, I'm new to the forum and have a question on my truck misfiring.
I have an '06 with 97k and was experiencing a misfire around 45 mph when shifting to OD. A friend suggested that it was either a plug or a coil pack and since it was time to change the plugs I'd start there. I had new plugs installed and it seemed to smooth everything out. Only a couple of days later the truck start to miss badly while accelerating at all speeds. Shuddering and chugging terribly. So next I had a friend run a scan to see what cylinder was missing. The error code was #3 so I changed the coil pack on that cylinder. The problem did not go away. I'm running out of ideas. Could the new plug in that cylinder be bad? Any suggestions would be helpful. Thank you
