05 5.4 shortblock w 20K knocking
Old 01-25-2015, 02:54 AM
Swiftyp's Avatar
2 years ago I had an injector fail open, bend a rod, and Ford put in a shortblock. I had em replace 5 other injectors, cam phasers, and plugs too. A few months later it had a subtle rattle on startup. Took it to em and they said it was the air cleaner being loose.
Gas prices got high n I drove an economy car most of the time. Got it back to em recently and they tell me it's throwing a low oil pressure code in the head. 20K on their build (but past their 12 month/12K warranty) They're telling me to **** off.
Can phasers or VCT solenoids cause that kind of noise/code? If I unplug the VFD will that help to diagnose if they are gummed up?
I'm some new breed of pissed but it looks like it's going to be my problem.
Thanks for any help,
Swiftyp
Old 01-25-2015, 09:27 AM
MGDfan's Avatar
Swiftyp
Can you obtain & post the exact code(s)? They *should* have noted the code on the work order / OASIS.
Oil pressure losses:
-failed timing chain tensioners (the seals blow out)
-plugged VCT solenoid screens
-plugged VCT solenoid valve body passages
-plugged oil pump pickup screen
Since the VCT/ valvetrain is oil-pressure driven, any of those can induce that noise.
What oil & filter is being used?
FWIW - I think it would have been prudent to replace all eight injectors.
Good luck.
Old 01-25-2015, 12:14 PM
Swiftyp's Avatar
I don't have the exact code. I should have been more clear. 3 failed (2 closed, 1 open). I did have the other 5 replaced on my dime.
Oil is 5-20 motorcraft. Motorcraft filter.
I appreciate the response bud..
Old 01-25-2015, 12:24 PM
MGDfan's Avatar
Roger that.
You really do need that code. If it's still doing it and you can safely drive it, go to Autozone , etc to pull it/them fer free.
One of these? Or something else?
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Input
P0523 Engine Oil Pressure Sensor/Switch Circuit High Input
MGD
Old 01-25-2015, 05:55 PM
Swiftyp's Avatar
P0349 and P0345.
Both cam position sensor.
9 is intermittent signal from sensor A bank 2
5 is lost signal from the same.
I found the sensor wire off the sensor, unhooked the battery, rehooked and started the truck. No check engine light but still has the noise.
I'm gonna pull the VCT and inspect/replace it n see what I get.
Old 01-25-2015, 06:05 PM
Swiftyp's Avatar
Screens are clean and look good. I guess I'll go ahead and replace to be sure but this isn't looking good..
Old 01-25-2015, 06:25 PM
MGDfan's Avatar
Well - that's a far cry from the 'low oil pressure' codes they claim to have found, lol. Not sure I'd trust that shop...
VCT operation can be observed (live data) with an advanced scanner, as there are PID's for same. That's one non-invasive method to check to see if the VCT system is responding normally. Otherwise the valve covers and front cover needs to come off. I;s also the only way to get to the VCT solenoid valve bodies themselves.
Did you try unplugging both solenoids to see if the noise stops?
FWIW - some additional info in this thread - including updated VCT solenoid and seal part #'s:
https://www.f150online.com/forums/20...ing-noise.html
good luck
MGD
Old 01-25-2015, 06:39 PM
Swiftyp's Avatar
I'll try that after dinner. I swapped the drivers side VCT and it had no effect.
Thanks again to all of ya,
Swifty
Old 01-25-2015, 09:45 PM
Swiftyp's Avatar
Tried it. Still there. I may be toast..
Maybe I'll come up with something..
Thanks again everyone..
Quick Reply: 05 5.4 shortblock w 20K knocking
