Oil filter adapter??
Old 01-11-2015, 12:28 AM
2001SuperCrew4x's Avatar
I beleive that this is leaking on my 2001 5.4. I have a question and I think I may now the answer but I am going to ask anyway. With the lower radiator hose incorparated with the adapter can coolant reach the oil? Im not seeing a loss of coolant nor is the oil milky, but I am just not sure when I can get under there to replace it.
Thanks in advance, Marty
Old 01-11-2015, 10:52 PM
DYNOTECH's Avatar
Yes it can if the oil filter adapter gasket is compromised either internally, externally or both. What leads you to believe that the adapter is leaking?
Old 01-12-2015, 03:54 AM
Getting a oil leak from that area. Not from above, so i think its either the adapter gasket or coming from the oil pressure sender.
Old 01-12-2015, 09:57 AM
glc is offline
I'd change out the sender first.
Old 01-12-2015, 05:11 PM
DYNOTECH's Avatar
I agree just be careful installing the new oil sender. You can over tighten it and create a crack in the adapter. Also be positive it is not from the oil filter. I know you said its not leaking from above but the filter sticks out away from the adapter and can drip directly down onto the it. Do you have a remote oil filter?
Old 01-13-2015, 12:38 AM
I can barely get my fat hands in there to remove the connector for the sender. I tried for an hour to get the connector off and got frustrated and quit. I just changed the oil and filter the other day. Really hard to tell where its coming from. No I do not have the remote filter.
Quick Reply: Oil filter adapter??
