5.4 3v msd or accel coils
Motorcraft or Visteon only. In an emergency, 'Araparts' COPs on Fleabay.
==> https://www.f150online.com/forums/v8...ml#post5114913
MGD
Accell is for sure junk. Same thing as the cheap Chinese coils you can get on e-bay for nothing. I've never seen anyone who has actually used MSD complain about them and my own experience with MSD products (that does not include ignition coils for a mod motor)has been excellent. Based on that experience I wouldn't think twice about trying them. I'd go after Vistion or Motorcraft witch are the same thing first though.
Any new coil set will make an engine run better if one or 2 are on there way out. The way the ignition system is designed its as high performance as you can get it right from Ford. I have the pre runner to Granitelli Moto blues and I've had 2 fail in 50k. I'm lookimg at coils right now because I've have another missfire issue. I'm wondering about the Denso coils. Rock auto say they are an original equipment part.. only less then $24 each. I might gamble on them..
I am getting ready to replace my Coils as well. I intend on using Motorcraft as everyone says they are best.
My question, I have already swapped the plugs to sp515, do the COPs stay the same as stock or should I be using a different version there as well? and..what is the correct part number for the 5.4?
Thanks guys.
Thanks guys.
rock auto list the motor craft part as MOTORCRAFT DG508 {#3W7Z12029AA, DG540} $42.74. I recently bought the denso 673-6000 rock auto says the denso's are original equipment supplier. I compared the denso coil with a Motorcraft and they look identical. I installed them and they all work but I havent ran them long enough to say much more. they are close to half the price. Denso's are made in USA.
