Coil packs
Napa has high-quality Belden boots ( complete with springs ) fer ~ $4 a pop.
Don't fegit to apply dielectric properly or it will all be fer naught:
The proper way to apply dielectric? That would be this - Courtesy of Jbrew and 88Racing:
Dielectric application:
1. Grease the plugs ceramic before install. This assures proper seat. Without it, the COP boot may buckle.
2. Pull the boot, then give the spring a couple tugs to make sure the spring to coil blade connection is secure.
3. Grease the entire inside of boot to protect against moisture and to focus coil pulse to the spark plug. Without it, pulse jumps, etches and leaves carbon trails inside of boots. Boots become weak and can deform.
4. Install the boot over the spring and onto the coil. With a small screw driver or curved pic, pull the spring from the end of the boot approximately one-half-inch. Slide the screw driver across the spring, keeping it from recoiling back into the boot.
5. Clean grease from spring end with a grease cutting agent. Lacquer thinner or brake cleaner works best.
6. Release spring so that it recoils back into the spark plug boot.
7. With a small brush or finger, grease the top seam of the boot.
8. Install coil.
Good luck
MGD
Just a quick FYI, We have the OEM boots for $6.44 each and OEM coils for $50.60 each.
http://www.tascaparts.com/oe-ford/3l...r=3l3z12a402ba
http://www.tascaparts.com/oe-ford/3l...tr=3l3z12029ba
-Steve
-Steve
Hey.
I don't mind, but others might.
Ye already gots an ol' Thread on the subject: https://www.f150online.com/forums/v8...-skipping.html
As fer yer question - I always recommend a complete boot/spring replacement whenever plugs are R&R'd. Otherwise its an incomplete job in my view.
After all of that, and you STILL get misfire codes ( and DID you pull those codes? If so post 'em ), replace the offending COP ( ideally, do them all once the problematic cylinder(s) is found.
If it still misbehaves, report back, as you then need to go deeper.
Don't know if you have seen this or not (dint check all yer verbiage):
==> https://www.f150online.com/forums/v8...ram-07m08.html
^^^Applies to yer model year & engine - behooves yall to get 'em checked.
Not trying to knock Belden specifically but virtually all aftermarket parts claim to meet or exceed OEM quality but that's rarely the case.
Motorcraft coils in particular seem to far outperform all aftermarket brands including "high performance" variants which is why when you look at fast, high powered Mustangs, Lightnings etc. they virtually all run OEM coils.
-Steve
-Steve
-Steve
-Steve
The two brands mentioned above haven't had any competition for years.
All other COP system coils (aftermarket), even the larger companies- import coils from china and put their color or sticker on them. The bad, - these coils use single wire build magnets and have poor frequency performance (RFI). Also, they lack the thermal protection Motorcraft and Visteon COP system coils have. One little surge can hurt them, shearing enough turns causing low grade misfires to start, then eventually complete failure.
