2006 5.4L 3v problems
Old 10-08-2014, 02:37 PM
mitymerc's Avatar
Exclamation 2006 5.4L 3v problems
I am working on a 2006 F-150 wtih 5.4L 3v engine for a customer. I rebuilt the transmission for him, which is working great now. I drove the truck for 2 days after the rebuild to make sure everything was working. It sat for 2 days, then I started it to move it this morning. After starting the engine made a very loud clatter noise, started running rough, started stalling and finally died, cranks by no start. code p0301 is stored for cylinder #1 misfire. It sounds very much like it jumped time.
would cam phazers cause this? if so, how do I test them?
Old 10-08-2014, 02:52 PM
One thread per subject please, just causes to much confusion for someone trying to help. I will remove the other thread.
Old 10-08-2014, 04:46 PM
mitymerc's Avatar
sorry about the 2 posts.... I wasnt sure where it would bet the most responses.
so, anybody know where I should start? how do I diagnose failed/failing cam phazers and how can I check if engine is still in time?
Old 10-08-2014, 05:48 PM
MGDfan's Avatar
Hi.
https://www.f150online.com/forums/ar...placement.html
http://www.f150forum.com/f4/5-4l-3v-...hlight=phasers
http://www.f150forum.com/f4/final-re...hlight=phasers
http://www.f150forum.com/f4/any-theo...hlight=phasers
http://www.f150forum.com/f68/5-4l-ca...hlight=phasers
http://www.f150forum.com/f4/please-r...hlight=phasers
... and many, many more - on both sites .... Sorry - on vacamacation - I'm not searching anymore.
Consensus:
-IDS / advanced diag tools required to 'exercise' the VCT system to drill down to the root cause/failing components. These tools allow manual commanding of the VCT system. There are several PIDS defined for the various system components. This is designed to facilitate either confirming or refuting the VCT/timing system as being the cause of the concern to begin with.
IF it turns out to be the most likely candidate:
- Use Motorcraft components.
- NEVER use Dorman.
- Replace VCT solenoids with the latest revision. These: http://www.f150forum.com/f4/vct-sole...6/#post3013236
- Do not just replace the phasers - - opportunists ( the smart folks) will also R&R the tensioners (notorious fer leaking gaskets and bleeding out), chains & guides.
Other suspects - bad injector (leaking), bad cam follower, failed plug. Thing is one failed cylinder usually won't prevent the engine from at least running ( but like crap). Out there = FPDM. Out there #2 = dropped valve. Borescope anyone?
good luck
MGD
Old 10-08-2014, 10:19 PM
mitymerc's Avatar
Just what I was looking for, thank you sir
It appears I was mis spelling "phaser" so my search results came back with nothing.
Old 10-09-2014, 05:15 PM
mitymerc's Avatar
I pulled the passenger side valve cover today
I think I found the problem....
#1 cylinder dropped the front intake valve, broke the lifter and rocker arm
#3 cylinder rear intake valve broke the rocker arm, the other half of the roller is missing
I fished around in a few of the puddles oil in head looking for parts, the magnet came back fury
An added bonus... I found a oil jug seal floating around under the valve cover.
Old 10-10-2014, 12:46 AM
Skew12's Avatar
Well. That'll do it.
Old 10-15-2014, 05:28 PM
slo5oh's Avatar
Owner:
"Lift and peel"... directions unclear, do I add this part to my engine too?
True story:
My friend got a case of oil for Christmas from his Aunt. Did an oil change the next day and topped off the oil in his b210 Datsun to the tune of about 10qt. Drove it about 2 to 3 miles SMOKING like a chimney the entire way.
Old 11-06-2014, 12:08 AM
mitymerc's Avatar
It was decided to fix the truck with a reman head and new timing components. The owner of the truck came up with some money and I got most of the parts last week.
I installed a reman right head, new VCT solenoids, new timing chains and tensioners and right cam phaser.
I got the timing cover on today but don't remember where the top bolts go. I think the ones with threaded studs and nuts go on the left side for the power steering bracket.
Old 11-16-2014, 10:21 AM
mitymerc's Avatar
Engine has been back together for over a week now. when I first got it running, it I thought I had mis-timed the cams, because it ran really rough. After some guidance from a several Ford Master techs, I finally figured out the # 5 spark plug was not firing. New spark plug installed and it runs much better now.
Quick Reply: 2006 5.4L 3v problems
