4.6 Engine Mount Bolt Specs
Does anyone know the bolt specs for the main engine mount bolt on the drivers side?
Part # W711403S439
http://www.ebay.com/itm/04-12-FORD-F...-/300922644297
Thanks!
Part # W711403S439
Thanks!
Not sure about the length, but I think it's a M12x1.5
The strength should be stamped on the head of the bolt. It's probably 10.9 or 12.9
I assume you're missing the bolt, so You can always take the bracket off the block and go to your local nuts & bolts retailer to match one up with a washer. Doubtful that you'll find one with the same size head on it.
