4.6l Engine Swap
4.6l Engine Swap
I'm looking for some help with my truck.. I have a 97 f150 4.6l. the motor recently left me sit at almost 190xxx miles on the motor. I'm looking to drop a 4.6l crate motor back in. So here is my real question... I want to drop in an '02 or an '03 4.6l in. Since it is the same block I shouldn't have any issues bolting up I don't think. but I know that I have a Pre-PI motor in currently. The crate motor would be a PI-motor and im wondering if my computer is compatible? I already know ill need a new intake manifold since the heads are different from what I already have.
Any help is greatly appreciated!!
Injectors are the same. As jethat said the engine will run ok with the original tune in fact my 97 has a PI Romeo 4.6 engine in it running on original ECM/Tune and it runs just fine. Good luck its a pretty straight forward swap. Use the original wire harness, coil packs, lower and upper coolant inlet and outlet (trucks have slightly larger diameter coolant inlet and outlets than cars. Basicly everything you had on the original engine can be used on the new one except the intake manifold and intake gaskets are PI as well. Get new exhaust manifolds and install them before installing the engine a lot easier in my opinion
