Help! What could have done this to my plug
Hello I had my code read it was p0301 my #1 cylinder is misfiring so naturally i took out the plug to see this..It is absolutely fried the electrode is completely disintegrated. Does anyone know what caused this? Any thoughts are welcomed. Thanks for your help.
v8 5.4
just put a new intake manifold with all new plugs and coils and wires about 3 mos ago.
for some reason i am having difficulty attaching my pic
v8 5.4
Bosch platinum +4: Misfire at 25,000 miles (but their O2 sensors and Icon wiper blades are awesome)
Champion platinum: Broken isolator on numerous vehicles within 20,000 miles
NGK Iridium: Low-grade random misfire immediately after plug change in a 4.6L DOHC, but ran fine in my V6 Lincoln LS
Motorcraft platinum: Low-grade misfire on one cylinder, likely a coil that was a little weak
Every one of these problems were resolved by using Autolite XP, Motorcraft fine-wire, or AC Delco plugs. For that reason, I use Autolite XP in nearly everything (including my lawn mower).
But when working on an import, I go out of my way to use Motorcraft plugs just to screw with the next guy who changes them. Most recently a Kia Sportage and Toyota 4Runner that happened to have a Motorcraft fine-wire plug available for it at the local parts store.
Not sure why the top of the line NGK plugs caused a rough idle and low-grade misfire immediately after installing them. This was my 2003 Mercury Marauder that I had bought new. But I had no issue with them in my V6 Lincoln LS or motorcycle.
Some of it is a matter of opinion and personal experience. I've had no issue with any Autolite plug. Running the cheap copper plugs in my sister's 5.0L Explorer right now and they're doing well, although I'll be changing them at 30k instead of 60-80k.
I'm not sure why anyone would run a plug less than Ford spec and be proud of it.
Meet or exceeds and it's not just opinion.
Motorcraft
Denso
NGK
That's how it's always been for tenth generation. Autolites, -not one of them meet Ford spec. Like them all you want, but you could do MUCH better. I know you could.
What you said about Motorcraft and NGK is something I haven't heard from anyone...honestly! The three mentioned most definitely do.
But hey, if they work well enough for you, I guess that works...for you. But it' right comparing them to plugs that have proven themselves for decades. Autolites may work, how good ? That's always a roll of the dice. Who wants to screw with that ??
When in doubt, go by what the engineers recommend. That would be the plug SPECIFICALLY designed and specified for these engines. - It's in the book.
Motorcraft
Denso
NGK
on
That's a broad statement. Based on my experience in many vehicles, I've had the following issues:
now on the 4.6+5.4 97-03+04h.....Denso and ngk are a suitable aftermarket alternatives if the oem one doesn't want to be used....
but bringing this back to the real world....I'll make this statement....All sparkplugs are manufactured, where as there's any number of things while it was being built that can affect its operation in ones vehicle....
Motorcraft
Denso
NGK
Motorcraft
Denso
NGK
To this day I have no idea why the NGK Iridium caused the misfire in my 2003 Marauder. I am a perfectionist when it comes to setting the gap on spark plugs, so that's not the reason. It's entirely possible that those plugs had some unseen damage from handling before I acquired them, and it's the only vehicle I had an issue with on them.
I default to Autolite XP because it's the one plug that I've had zero issues with on any vehicle. A fine-wire plug is less likely to have the flame blown-out and provides a more consistent and focused spark. Initially a fine-wire plug would have a shorter lifespan since there was less material present and they would wear faster. Spark plugs using Iridium solved this issue as it's more durable than platinum, but more expensive as it's a very rare element.
Short version: just because a part is aftermarket does not make it inferior. Using an OE plug is the safest bet, but I fail to see how Denso and NGK are superior to Autolite.
Here's some good general information.
I realize this can spark big debates just like "what type of oil is best" threads. What I mentioned is from my own experience with many vehicles. Most plug changes go fine, but the ones that go badly stick out in my mind.
http://youtu.be/7N-7WGfnKHo?t=3m39s
So I took it to ford only to be charged like $200 for exactly the same thing that autozone told me for free ...a miss in cylinder 1 and base motor problem that they couldnt identify without charging me an additional $250. GRRRRRR.
first it was the #2 and #6 cylinders llike not even 3-4 mos ago. What in the world keeps causing this?
