Need help!
Need help!
I have a 2004 F150 XLT with the 4.6l V8. A month ago problems began stacking up. At speeds above 40 the truck becomes very sluggish, almost jerky with a severe lack of power. So I began to check things off the list by replacing items I was able to do.
Replaced,
PCV Valve
Fuel Filter
Spark plugs
Transmission fluid & filter
Cleaned,
Throttle body
K&N Air filter
MAF sensor
Before changing the plugs I had a misfire code and so I replaced cylinder 3 COP. Finished up yestarday with a test drive. 0-40 very soft and smooth, but no power. Above 40 absolutey no power aand truck shutters and seems to be struggling overall. Please, can anyone help? Is it something simple or do I need to take it to a mechanic? Willing to try anything. Love my truck and life without it sucks! Again, please any help or advice is beyond needed and very appreciated!
Replaced,
PCV Valve
Fuel Filter
Spark plugs
Cleaned,
Throttle body
K&N Air filter
MAF sensor
So lost
I installed OEM, motorcraft platinum spark plugs. Had Autolite plugs in it. As for type of coil packs, unsure. New one was purchased at O'Reilly's. Others are yellow, sorry all I know about them.
How would I check the fuel pressure? Also with no codes or check engine light on, how am I do know for sure if it is the Cat?
Is there anyway to test COPs to maye find a bad one? Would a bad CAT not give a code or could it go bad without a code or check engine light? Also what would be the best replacement CAT? I am looking at Magnaflow. I am a disabled vet who has limited funds, however I only want the best, but without breaking the bank, ya know.
Also I would suggest getting rid of those aftermarket cops. They have been known to be junk. Replace with motorcraft, Visteon, or araparts cops
For checking the fuel pressure you can read it the your obd2 port. It's all electronic.
So I looked under the truck and my new questions are how to get the passenger side exhuast out? I also am unble to see where the first bank on the same side, gets unplugged. I am having trouble getting the 2 O2 sensors out of the driver's which I was able to get off and the section from the mounting spot to the headers to about 3 inches past the second converter. Then my last dilemma is going to be how am I to put the O2 sensors back in after i get the new Magnaflow, high flow cat in place. Iam no mechanic but if I can do the job then i am willing to try anything I can . And will anything get damaged if the truck is started with no exhast?
