Oxygen Sensor Stuck, Help!
I'm running out of ideas to get my driver's side upstream O2 sensor out. I have the Auto Zone kit with the special sockets. Yesterday I turned the socket almost to the point that it spun on the sensor. I used quite a bit of the wd40 rust release penetrant. Tried propane torch as well.
Today I put a hose clamp on the outside of the socket to help prevent it from spreading and I'm still getting nowhere. Tried hitting the sensor with a hammer and punch. Tried running the engine 10 minutes to heat it up then put the propane torch to it all while leaving my ratchet wedged in there to keep torque on it.
Does anybody have any other tricks?
on
1 Post
While I like WD40 I don't think it works well to remove rusted parts. You would be better off with Liquid Wrench or something like it that. Soak it let it sit overnight and try again. If that doesn't work heat is your only other chance. Heat it up red hot and it will come out. I honestly have not replaced too many O2's but I have always needed to heat to get them out. The guy that did my exhaust told me heat is the only answer to get them out and 9 times out of 10 you destroy them doing so.
When that happens to me, I just cut the wires off the sensor so I can get a regular 7/8" or 22mm socket with a breaker bar on there. Works every time. If space is limited, you can use a box-end wrench. If using a box-end wrench, it helps if you hit the wrench with a hammer. The special O2 sensor socket isn't that strong. It it's a really odd area to get to, try a crows foot wrench.
