2003 PI 5.4 swap complete, will not idle but revs ok after 2000rpm
Has anyone done the swap and had this problem? the 4.6 was running fine in Dec 2012 when I initially removed it (other than a bad head gasket and no CEL codes). I reused everything except the 5.4 shortblock is from the junkyard. It will fire up and then die unless I pump the gas pedal. I can keep it on idle around 800 rpm if I continuously lightly pump the pedal slowly. If I mash it to half throttle or more, it will slowly rev while stumbling and after-firing until it gets to 2000 rpm then it smooths out and will rev instantly from 2000 to 4500, but it will die if I don't tease the pedal. No smoking, and no CEL has occurred.
