460 stored
Squirt some oil in each cylinder before turning it over just to avoid the possibility of dry rings and scratching the cylinder walls. Temp controlled room or not, I would inspect all rubber components just in case. It's more about humidity/moisture also, not so much temperature as to whether there is the possibility of internal rust or deteriorated parts. The fact is, the motor is out and easy to work on so check it over thoroughly and replace any hoses, wires or gasket that could be a problem down the road. There should be no problems
I agree with the others about how to prep the motor. You need to assume that whatever assembly oil was used is dried up by now. If you have a motor stand turn it upside down and remove the oil pan and give everything a squirt of oil before you try turning it over. A pan gasket is way cheaper than a galled crankshaft.
