4R70W shifts late, sometimes.
Highway driving causes High Idle
Howdy All,
I've dug around and could not find much on my issue.
I have a 1999 F150 5.4 with a 4R70W.
The tranny will shift fine if I keep a light foot, but if i step on it a little bit it acts like there is no overdrive and won't shift until 2500-3000 rpms.
It also does this after it's warmed up, but only for a short time.
I've changed filter, flushed tranny (with Lucas added), and changed TPS.
I hope I've supplied enough info to solicit some help.
Many thanks, in advance.
/**04/08/2014**/
Edited Title
/**04/08/2014**/
Edited Title
Ya I think I wasn't as clear as I could've been. It's not that it just takes a while to shift when pressing on it, the issue is that after pushing on it and then driving normal, it gets 'stuck' so to speak. Plus, I would think driving on the highway at 1500 rpm would be crowding it. After I get off the highway, slow down, and gradually accelerate again, it does the same thing.
I appreciate the reply though.
It has no codes active or in history. I can't say that I've seen the OD light flash at all. I may have missed it (given the position), but don't think so.
Good to know about Lucas, thanks. Although I have to say that I have not noticed any difference since the flush (about 10K miles ago).
Ok, so I noticed something else which makes me wonder if it's even the tranny. Whilst it was having symptoms I put it in park and the idle was at 1300 rpms instead of the normal 600. That would make sense that the shift points would be skewed. I will continue my search, thanks for your thoughts.
