swapping out 5.4
Old 03-23-2014, 05:17 PM
rob maili's Avatar
swapping out 5.4
Have a 98 5.4 flushed it out and over heated, thremostat mangles, bad head gaskit leak ( watere pouring out the tail pipe ) knocking middle of motor ? cam lobe crack ?
anyway I have a 5.4L from an 05 to 10 F150 Ones a two valve and ones a three, but I have to whole truck computor ect.
Can I swap them ???
Old 03-23-2014, 05:39 PM
2V 5.4s are from 97-03. 3Vs are from 04-08, and 4V are from 09-10. That info needs to be sorted out first
Old 03-23-2014, 05:47 PM
rob maili's Avatar
Is it possible if a 3 or 4 valve
motor should fit
If change whatever electronics
will it run
also the 98 ws bifuel but I took out the propane
Old 03-23-2014, 06:58 PM
jethat's Avatar
swapping to 3v is not practical. it might be possible with a whole lot of modification. Much better looking for 2v engines. 97-03 in F150's. You could make a 2v out of a E van work but you would need an intake out of a PI truck. 98 is non PI so your intake wont swap to a newer PI engine.
Old 03-23-2014, 07:57 PM
4v's were not used until 5.0 in 2011. 3v's were still in 2009 and 2010 but had upgraded 20hp.
Old 03-23-2014, 08:06 PM
glc is offline
If you have a 05 or later 5.4 2 valve, it's out of an E-van. You can swap it, but you will need a PI truck intake.
Old 03-25-2014, 12:52 PM
rob maili's Avatar
the motor is a 4.6 04 from the vin 1FTRF12W94NR08145
something is wrong wrote the vin wrong but the motor and year is there
no computor was smashed or removed Think it wil work if not I have to buy another truck this is my spare thanks for the comments
Old 03-27-2014, 12:22 PM
SUPERLOOP's Avatar
The 12th digit should be B and not a R. 1FTRF12W94NB08145
Old 03-29-2014, 12:45 PM
rob maili's Avatar
going to give it a shot both 2 valve exhaust has to be modified see waht happens
Old 04-05-2014, 10:51 AM
crazynip's Avatar
There is no 4v 5.4 that went in trucks... 3v 5.4 2004-2010. They never put the 3v in the van, so E series van 5.4 and 4.6 were 2v from whenever they changed them, 1997 I think until 2014
Quick Reply: swapping out 5.4
