05 f150 4.6 sputtering at Idle
I have a 05 f150 w/4.6 107k mi. Regular scheduled maintenance throughout history and I am the original owner. Today while driving, my truck sputtered once when it warmed and stopped. I let it sit for a couple hours and started up just fine. This evening taking it out again it started again after it got warm, this time worse. At a stop light at idle it feels like it is about to die. When accelerating, there is little to no gitty-up at any speed... this only happens when engine is at Op Temp. Throughout any RPM (if any) there is no change in sputtering except then it starts bucking and shaking. She starts just fine when cold and no problems until warm
Bosch plugs are the biggest no-no in these engines. They actually come apart!
The FPDM controls fuel pressure, and it varies by design. You have to have a scanner that can read the PID. There's no way that COPs can be tested without some expensive bench equipment, resistance checks don't tell you if they are breaking down under load.
I'd pull the plugs and at least look at them first - I'm betting you probably have at least one that looks really nasty.
http://www.ebay.com/itm/VISTEON-60-1000-Ignition-Coil-Ignition-Coils-/330836213376?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d075ffe80&vxp=mtr
OEM quality coils, cheaper and better than parts store coils.
