97 ford f150 4.6 running rough
I got a 97 ford f150 4.6l tht was sitting for 4 years cuz of broken shackle. I fixed the shackle, fresh gas, changed the oil and filter, New spark plugs and wires. Now it is running really rough. Idles really low and rough and almost stalls out when pressing the gas. CEL on with cylinder 7 misfire and bank 2 system too lean codes. Any advice
It will start up the 2nd or 3rd crank. It will sit there and idle ok until u hit the throttle and it will baug way down to almost stalling. It revs up good when u get the rpms up. When I put it in gear it idles way down and it has almost no power when hitting the gas to where its not drivable
Well I tested the fuel pressure today and with the key on engine off there was no pressure at all and with the engine running there between 10 and 20 psi.I put on a fuel pressure regulator I got from the junkyard but still no change. The fuel filter wasn't clogged. The fuel pump is still working cuz I can hear it and I used it to pump all the gas out once. When I first got the truck the filler neck where u put gas in at wss completely rusted out. It has big rust holes in it.im thinking some of the rust frm the filler neck got down into the tank and is clogging up the fuel pump. Does this sound like a possibility?
