sensor connections on 1998 4.6
Can someone guide me here ? I'm swapping a expedition engine and found a plug w nothing to plug it to ! Does the sensor in center of block under intake plug to the mass air on the air intake or does it go to the back of the engine ? idk if im missing a sensor or if i dont have a o2 plugged in back or what ?Didn't realize ford placed same exact plugs all thru the harness ! that's almost as handy as having over a dozen bolts on a valve cover ! Genius engineering 4 sure ! thanks in advance !
where or what does the mass air connect to ? That head genius engineer at ford could of easily made all those connectors just a little different than the next to simplify things ! I guess they were spent after that valve cover design they were all outta design break thru's ! thanks 4 the help !
Why don't you go to Ford and straiten those people out for the rest of us, ehh...
